been reading and looking at camshaft part numbers, and it seems that they can not be identified by the marks on the cam themselves?
and one must measure the lift of the cam to find out!
is this so?
if so, can i measure across the base circle and then subtract that from the tip of the lobe to the bottom of the base circle measurement ?
never measure a cam before so sorry for the noobness
there is a mention of the 034 AM ex cam i have being a 7A cam on another forum.
steve
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
