Noisy fan belt on start up
  • darkhorse1210
    • May 2010
    • 335
    This is no big deal but it annoys the hell out of me
    Everytime I start the car up I get that squeking noise that I'm guessing is the fan belt, it continues for about 30secs afterwards. If water is poured on the belt the squeaking stops immediately but I'm not going to carry a watering can round with me for everytime I start the car
    So, does anyone know of any wonder lubricant (KY Jelly answers need not apply) that will (a) stop the squeak and (b) maintain the friction required?
    Ta
  • s2driveruk
    • 12696
    Hi,
    presuming is the power steering pump belt as the fan is electric.
    Usually a sign of slipping ot age of the belt itself, i'd adjust or renew personally, the noise will just keep coming back. from memory you should be able to twist the belt up to 90degress with thumb and forefinger only, if looser then need to tension it up.
    1992 3b S2 Coupe
    • darkhorse1210
      • May 2010
      • 335
      Originally posted by s2driveruk
      Hi,
      OK, cheers for that, I'll give it the 'twist test' later
      • Ryss
        • Nov 2009
        • 233
        • Country: South Africa
        It will be the alternator v belt. Its very short so the 90 degree test may not be the best test. I just look for no more than 1/2 inch lateral movement. Belts get old and hard, and wear on the sides, which causes it to slip as the alternator boosts charge on start up. If so replace the belt rather than over tensioning and putting a strain on the alternator bearings.
        Regards
        Ryss
        www.autostart.co.za
        • M_GORDON
          • Oct 2008
          • 1295
          • Home: Isle of Man Current: Vatican City State
          Hi
          Mines is very sondly one alternator's belt. And... I just changed 500kms ago for other new one and the same sound comes all the time when I turn on the engine
          photobucket SUCKS
          • WidowmakerS2
            • Oct 2007
            • 354
            • Current: Norway
            Originally posted by M_GORDON
            Hi
            They stretch quite a bit right in the beginning, so IMO all you need is to tighten it up.
            If at first you don't succeed, destroy all evidence that you tried.
            -CQ 3b "S2".
            • M_GORDON
              • Oct 2008
              • 1295
              I prove it
              photobucket SUCKS
