egr cleaning
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    egr cleaning
    Sorry for this guys....but...somebody knows a method to clean the intake and head from the carbon build'up caused by the stupid thing called EGR?
    I have removed the entire intake....but...at the head i am stuck....how to clean inside the head without removing'it.
    Is unbelivable how much crap i found there in 130k km.
    the intake was 50% blocked....
    Thank You!
    Eugen
  • s2driveruk
    • 12696
    yeah they make a right mess - i had to clean up my old A6 avant AJM and ended up just removing the IM, EGR/TB and working with a Wynns specific cleaner (forget the name though) Also if you have VVT turbo, worth cleaning that out too and ensuring it moves freely too
    1992 3b S2 Coupe
    • AndyP
      • 6049
      If it's as bad as you say I wouldn't try cleaning the head on the car, too much risk of stuff dropping into the engine. I'd take the head off and take it to an engine shop with a 'hot tank'.
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        I remove'd all...and cleaned everything i could reach...but...the intake ports from the head? I was thinking to turn the engine untill i know the intakes are closed and spray some cleaner and wipe what i can there...but..i thought that, maibe, there is an better option, not only for cleaning, for maintaining also.
        Thank You for reply's!
        • Louie C
          • Jun 2012
          • 288
          Anyone any thought's on blanking of the EGR valve? I recall reading about it somewhere, I take it that a S2 with a decat RS2 exaust would more than likely never pass the emmisions if you blanked it off???
          • 1781cc
            • Nov 2011
            • 1253
            Originally posted by Louie C
            Anyone any thought's on blanking of the EGF valve? I recall reading about it somewhere, I take it that a S2 with a decat RS2 exaust would more than likely never pass the emmisions if you blanked it off???
            • ManiacuV6
              • Dec 2009
              • 458
              • Country: Romania
              You bock the EGR but the ECU won't be happy . So you neeed to cancel EGR from ECU.
              Eugen's method with closed valve and with cleaning is ok . I don;t have another one in mind right now.
              L.E.: DO you have an Engine code ?
              Audi S4 2.2T 5 spd 1992 for parts
              AUDI A4 1.9TDI daily use
              Audi 80 Quattro 2.0 16V (ACE) aka Competition
              • 1781cc
                • Nov 2011
                • 1253
                I havent touched the ECU and everything is running fine, no codes, full boost, runs well (!?)
                • ManiacuV6
                  • Dec 2009
                  • 458
                  • Country: Romania
                  IS it a diesel ? I don;t get it .....
                  • 1781cc
                    • Nov 2011
                    • 1253
                    yup, its a diesel dog mate
                    • pasbogdan
                      • Sep 2009
                      • 1160
                      • Country: Romania
                      Get manifold off,put diesel in it and burn it.After that get some metal chain or anything in it and clean the burned material.Check for flatness and if necessary reface it(to head and to egr etc).I spend 1 day trying to clean a 2.5 tdi 700.000 km manifold with all kind of products,brushes etc.On the inside no chance.After the fire all was like new.
                      • Pirvu Eugen
                        • Apr 2007
                        • 1978
                        • Country: Romania
                        Is an Opel 1.7 CDTI. Z17DTL engine. I dont want to remove the head....will be much better if i could blank off and keep the light off. I tryed but...the ecu is going to limp mode. I dont know how this ecu check for egr flow....as the temp sensor is in the maf.
                        At the old Y17dt i could blank the egr without problems..but at this no...
                        Sounds like i need an remap with egr delete...
