Looking for an UrS6 ECU to borrow.
    6spd manual version. Needed to confirm problem with existing ECU.
    Not me. Someone in the UK (Damien). I know he is with an airline so maybe in the London area. I will confirm.
    Dave F.
  • AUDIDOIT
    • Mar 2008
    • 30
    • Home: France Current: United Kingdom
    Hi Dave
    Really appreciate that post. Yes guys as Dave said. found out today my ecu is fried so will be needing another one to replace it. If anyone has one to sell for a decent price please send me a pm.
    many thanks
    Damien.
    • djh
      • Jun 2011
      • 1622
      manual or auto?
        Originally posted by djh
        manual or auto?
        manual, as per my original post.
        • Thecrispynoodle
          • Jul 2012
          • 269
          Originally posted by AUDIDOIT
          Hi Dave
          many thanks
          Damien.
          Any idea what might have happened to it?
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            Damien,
            I got your message in the morning mate.How was the thing going?
            FYI I have 4a0907551B (from UrS4 Automatic w/o immo) ,4a0907551D(from UrS4 Automatic with immo)
            All the ECU boxes shares the same part# besides the last alphabet which defines model/year,immo system,transmission.
            the part# you sent to me last night it's supposed to be the transmission control unit.I have the actual box but
            don't know where did i keep it.
            one of a few I5 from Asia.
            • veneto rs2
              • Jun 2006
              • 1022
              • Country: Veneto
              I do have a Motronic form an AAN motor don't know if S4 or S6 (date on the ECU it's 03.02.95 So should be an S6?) believe it's from a manual one at list KATE says so....
              Code it's 4A0 907 551 C
              Will be happy to lend it and if needed I have the comlete motor loom as well.
              Stefano
              http://www.audisportclub.com/
              http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
              • veneto rs2
                • Jun 2006
                • 1022
                • Country: Veneto
                I believe the ECU it's in perfect order but note that it was savaged together with the whole motor (which it's not for sale) I have no idea neither if the ECU it's original or chpped.
                If I have to sell the ECU I could do it but in all honesty I have no idea of the right price to ask...
                If you want me to lend it to you no problem of course and no charge (apart shipping).
                Stefano
                • prj
                  • Mar 2010
                  • 6308
                  Try to get a UrS4 ECU, the UrS6 will have immo issues and will need to be coded.
                  • twoqu
                    • Sep 2003
                    • 3103
                    I have a brand new boxed 551C. It would be decentcly priced in comparsion to a new one!
                    However, first check the ecu number. If your have a S6 its likely to be a 551C or if lucky a 551E.
                    As PRJ has said you may need Vag com to replace like for like and want to retain the immobolizer. Of course you need to have eliminated the cause of the problem first.
                    • merlin's S4
                      • Jan 2005
                      • 1539
                      How has your ecu died? Seems odd for it to just give up, unless it got wet or something. Are you 100% sure it's dead? You'll need to know the cause either way as you don't want to fry a new one once you get it.
                        He says it has no 5V power coming out of pin T55/12 on the ECU which powers the TPS, G40, F96, G62, G42 (bottom right row of devices in this diagram):
                        • prj
                          • Mar 2010
                          • 6308
                          No power with the ignition on?
                          Are you sure that 5V is not short to ground somewhere or inside a sensor ?
                            Originally posted by prj
                            No power with the ignition on? Are you sure that 5V is not short to ground somewhere or inside a sensor ?
                            On another forum. Damien said
                            "Hi Dave, to be honest it was a process of elimination. The fault codes were TPS and cam sensor. But when the sensors were tested independently they were fine. Also no juice is going to any of the the engine sensors from the ecu power source. So we are pretty sure it is an ecu based problem? Also the engine temp is showing -30? So i am going to remove the unit from her tomorrow and get it sent away for inspection. "
                            Damien is working with a mechanic on this.
                            • prj
                              • Mar 2010
                              • 6308
