Hi guys, I noticed the other day my Holset HX40, started sweating a little oil near the hot side of the turbo (in the middle where the oil lines go)(you can see in the pic a little sweating), before I went ahead and took the turbo of, I started the car once more, and at idle it was smoking a little bit and when reved up would smoke a good amount. (VEMS lambda was reading good so not a rich fuel problem). Once i let it run, it would smoke right where the downpipe and hot side flange meet (must have seeped out of there), also by the bolts seen in the photo near the hot side.
Once I took the turbo of, there wasn't any visible oil by the impeller, but from the hot side i did notice when I peeked inside that there was a little oil/sludged oil.
Intake side was fine just had oil moisture around the housing.
Any ideas if the seals went inside or what could be the cause (weird cause turbo was rebuilt by previous owner supposedly (2000miles ago when i put it on).
