AJA diesel block
  • kelys
    • Jan 2010
    • 71
    • Country: Denmark
    AJA diesel block
    I got a aja diesel block, but i can not see where it should be welded. Is it right, that the only thing i should make, is close one hole in the block
    Kenneth
  • caterpillar
    • 2480
    ok... the AJA block dont need weldin; bur the head(if you use the 7a or 3b 20v head... need some small weldin to seal the gasged... and you need to redrill the bolt holes in the head too..( se this forum about stroker)BUT the syl diameter are only 79,5.. you need to rebore to at least 81,00 ...then you need to deside how long the conrods you want to use..then order the piston with the "right" comp..try to fint some of the build threads in this forum.. ( stroker)
    what hp are you aimin??
    • caterpillar
      • 2480
      kelys@ ive send you PM in your inbox
      • diesel des
        • 3896
        any summary pictures of what needs done on an aat or ael tdi diesel block?
        • caterpillar
          • 2480
          AAT and AEL .. if the syl wear are ok.. so clean the block (hot tank it) and use it as is...only the head need some little mods...
          • diesel des
            • 3896
            I thought I needed to weld a part on the top corner of the block to make the gasket seat ok. no?
            • AndyP
              • 6049
              On the AAT/AEL block there is also an oil return hole that needs blocking. Most of the info is in this thread:-
              There are more pictures in my thread or JP's or Jamo's.
              • diesel des
                • 3896
                forgot that thread had the photos in. great cheers
                • Pat D
                  • Dec 2011
                  • 748
                  • Country: Australia
                  Food for thought
                  ABY S2 stroker (work in progress)
                  B5 1.8T quattro
                  B4 2.3 (decommissioned)
                  • caterpillar
                    • 2480
                    nice find...thanks
                    • diesel des
                      • 3896
                      the second photo, is that a frost plug or just a piece of turned steel? I have some high nickel rods so I intend on welding a piece to the block at the front.
                      • Pat D
                        • Dec 2011
                        • 748
                        I'm not sure what was used, I'm picking the block up up in a few days and will let you know
                        B5 1.8T quattro
                        • kelys
                          • Jan 2010
                          • 71
                          • Country: Denmark
                          Hi
                          Anybody who knows, where i can find some pics of welding a 7a head to fit a aja block
                          Kenneth
                          • caterpillar
                            • 2480
                            in the last pics, where the plug in the block ...in the corner.. the 20v head will not vover that... so minor weldin or make som thread in the block.. and plug it... you may try the dieselmls gasged, or the org 20v gasked( mls too) and test it...
                            • pasbogdan
                              • Sep 2009
                              • 1160
                              • Country: Romania
                              Check main line for roundness with caps torqued.2 anj and one agx(sdi 2.5) cheched and the less was 0.03mm.
