I've got smoke....
  • Ian Simmonds
    • Jun 2005
    • 2858
    I've got smoke....
    .... its fine on cold start, doesn't smoke when accelerating, or decelerating in gear (even at high rpm), but it gently smoulders at warm idle and gives a grey 'puff' when pulling away...
    Its all pretty much original except Miltek & Map.
    Any thoughts? I've got a couple, but I want a second opinion.
    93 MTMS2 Avant
  • irishs2
    • Apr 2009
    • 2455
    PCV blockage?
    Eric
    95 S2 Avant under rebuild.
    • Christophski
      • 3632
      Could it be turbo maybe? I think mine is leaking a bit of oil so am looking at options...
      • rafa89
        • Jun 2012
        • 74
        • Country: Portugal
        I think that could be turbo. It started one day to another?
        92' UrS4 2.2T
        89' 80 Quattro 2.3 20v
        93' 80 1.9 TDI
        92' 100 2.5 TDI
        99' Cabriolet 1.9 TDI
        • stocious
          • Jul 2012
          • 838
          could it be heatsoak from the new bigger downpipe, just a thought
          1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
          • K Simmonds
            • Dec 2007
            • 7627
            Turbo would be my first thought.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • pixsaudisex2
              • Sep 2004
              • 3110
              Just make sure your breathers are not blocked as mentioned above I had a new turbo and it still smoked took the fire trap out n all was good...
              • Ian Simmonds
                • Jun 2005
                • 2858
                Bless, I thank you folk, and love this forum... I'm Annual Leave next week, and job number one is clean out the PCV system, (I've already downloaded UrS4's threads and related info on the PCV...)
                I'm hoping this is it, as the car used to do a lot of motorway work, but as, for the last 3 years, dropped right off to a 3 mile each way station commute and the odd thrash...
                That said, turbo oil seals at 140k isn't unreasonable either...
                I'll clean out the tubes first, see how we go...
                Thank you folk... You really are stars
                VBR
                Ian
                93 MTMS2 Avant
                • Ian Simmonds
                  • Jun 2005
                  • 2858
                  Hmmm... If its the turbo, with a standard kkk24' is there a "cough", an 'upgrade' option as a direct swap
                  93 MTMS2 Avant
                  • DJones
                    • Jun 2005
                    • 2020
                    Ian
                    Ask David S2driveruk what he thinks of his, I got it upgraded for him when I rebuilt his engine. Bigger cold side wheel and (cant remember dimensions) I think it was a 3 degree cut back on the exhaust wheel.
                    It felt very strong at just 1 bar.
                    • s2driveruk
                      • 12696
                      Yep continues to feel strong I'll dig the detail out but the cutback sounds right. I'm hoping that I'll get it mapped with Automark later this year and get it optimised.
                      Now I have to time/life back, I really must document the build Darren
                      1992 3b S2 Coupe
                      • Christophski
                        • 3632
                        Well I'm looking at either a working used item if the price is right to keep me going until I am do what I want, a hybrid rebuild or an out and out swap and new manifold... I have a mate who says he will tell me what I need and help with all the work, matching and making items work together with new flanges and downpipes etc.
                        Will keep you informed Ian as we both jab very similar, almost identical cars.
                        Hope you figure it out too bud
                        • Ian Simmonds
                          • Jun 2005
                          • 2858
                          Superb, thanks folk, if it is the turbo it'll be shipped off to either universal or turbo dynamics, I'd just like a standard fitment with, if possible, a bit more 'blow' if that makes sense.
                          93 MTMS2 Avant
                          • DJones
                            • Jun 2005
                            • 2020
                            Ian
                            David's is standard fitment with more blow, it's all internal. Craig is your man at CR Turbos, used to be at TD I followed him to CR.
                            Darren.
                            • DJones
                              • Jun 2005
                              • 2020
                              Lol, it's out of warranty......
