rs2 start problem again
  • fatiii
    • Nov 2010
    • 130
    • Country: Turkey
    hi all. i know tried of me the all off but there's no one else to help you..
    i have a new problem.i opened the engine for upgrade rods,studs,cams vs vs.but after collecting the engine will not start..i think timing is very well but what is your thinks?
    the ignition and fuel running smoothly
    the krang timing calibrate the top of the first piston.is it true?
    it is cams timing..
    and the last one sorry my bad english
  • david
    • Oct 2008
    • 1268
    check the marking on cambelt pulley i think it's in line and probably that's where the problem is.
    it well known that rs2 timing do not line up properly,you need to line it one teeth back.
    checckout the pics
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
    • irishs2
      • Apr 2009
      • 2455
      It shouldn't stop it from starting , just prevent boosting. Anyway I think this is an not an adu engined rs2 if I remember correctly..
      Eric
      95 S2 Avant under rebuild.
      • david
        • Oct 2008
        • 1268
        yes it will if timing is even slightly out
        • Avantus
          • Sep 2007
          • 941
          • Country: Belgium
          My RS2 wasn't one tooth left when I bought it, causing it to cut out at something like 4k rpm with a hall sensor fault. It did start perfect however so I think you need to look further.
          Didn't damage the sensor?
          • david
            • Oct 2008
            • 1268
            irishs2
            if it not ADU and it a ABY then something else must be wrong
            • irishs2
              • Apr 2009
              • 2455
              It started out as a 3b but cannot remember where it ended up.
              Eric
              • fatiii
                • Nov 2010
                • 130
                • Country: Turkey
                checckout the pics
                how is it now?
                • fatiii
                  • Nov 2010
                  • 130
                  • Country: Turkey
                  it is working perfectly about 400 hp but i want more power so open the engine for upgrade..
                  • A80Avant
                    • 10873
                    • Country: Greece
                    Looks better now. Try it
                    • fatiii
                      • Nov 2010
                      • 130
                      • Country: Turkey
                      What is your thinks?
                      • stocious
                        • Jul 2012
                        • 838
                        Why do the cam wheels have flat teeth ? Are some like that ?
                        1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                        • stocious
                          • Jul 2012
                          • 838
                          Is it still on a distributor ?
                            That is correct. (but We won't start that thread up again)
                            Fatii doesn't say whether he is running the 3B distributor (and G40 Hall sender or not).
                            The cam sprocket he is using is the ADU 105B (where B = ADU).
                            • A80Avant
                              • 10873
                              • Country: Greece
                              From memory I think he is on coils and vems
