Removing urs4 fuel pump
  • diesel des
    • 3896
    So how the fffff do I get the fuel pump out of the bottom of the tank. I have removed the sender etc ok but getting the pump out looks like a lot of plastic smashing going to happen. So what's the trick or magic word required... Cheers des
    Sent from my GT-N7105 using Tapatalk 2
  • spink
    • 4382
    sorry Des forgot to reply to your email last night
    the pump comes out if you prise apart the 2 tags and pull the pump upwards,or you can twist the whole lot out if you have the 'special tool' which is a drain pipe chopped to about 4 inchs long with some bolts screwed into it lol
    If I had have thought on I would have removed it all for you before sending the tank but I was more concerned containing the smell of petrol
    • merlin's S4
      • Jan 2005
      • 1539
      This is my tool for removing the pump...
        Revised C4 Fuel Pump Replacement DIY
        Des: Surprised and disappointed that you missed/forgot about my post:
        All the tricks and photos are there. Trust me.
        • diesel des
          • 3896
          great info guys. sorry urs4boy I have been flat out replacing suspension, stripping engines, removing tank and normal life stuff. your links are great.
