Max boost from k24 7000?
  • BorisShakhov
    • Feb 2009
    • 224
    • Country: Russian Federation
    Mates, I need help again:banghead:
    I have trouble with max boost...
    Only 1.4 on 4gear than down to 1.2 near redline
    Same figures with blocked wgfv tube.
    My setup is:
    3bar map sms chip
    Supersprint without cats
    All other stock
    What is a maximum for k24 7000? (not by the dashboard lcd)
    And another question is, how to check leaks after a throttle body?
    Injector seats especially
    Any links?
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    That's normal I think..max safely on a k24-7000 is 1.5ish and it is normal that it tapers down to 1.2/1.1 to redline.
    Don't think a 3 bar mps is required when using stock setup either.
    1996 S2 ABY Silver
    • K7ERG
      • 1711
      I run 1.5bar on my AEL ( diesel) with k24 7000. No problems for 6 months.
      Audi A6 AEL 5cyl Quattro breaking.
      Audi A5 3.0tdi Quattro Stage 2
      07947385043
        Originally posted by rynaqui
        That's normal I think..max safely on a k24-7000 is 1.5ish and it is normal that it tapers down to 1.2/1.1 to redline. Don't think a 3 bar mps is required when using stock setup either.
        Agree but he says he has SMS chips with the 3 BAR MAP sender.
        • prj
          • Mar 2010
          • 6308
          Uhm, 1.2 bar to redline is already way too much.
          This turbo can't even do 1 bar at 7000 rpm. More like 0.9.
          With 1.3-1.4 at redline you already have 350 hp on RS2 turbo.
            S2 3B/ABY and RS2 ADU boost leak testing
            Originally posted by Frusciante
            ...And another question is, how to check leaks after a throttle body? Injector seats especially. Any links?
            Use Option one in this boost leak testing post. Use a spray bottle with soapy water and look for bubbles around the injector seats. Might need new seals and/or seats if that is a leak location.
              Originally posted by prj
              ...With 1.3-1.4 at redline you already have 350 hp on RS2 turbo.
              Not with stock injectors. Aren't those limited to about 280 hp?
              • BorisShakhov
                • Feb 2009
                • 224
                Have swaped wg cap with a stock one just 5 minutes ago. Will see...
                  Why do you think changing the WG cap will make any difference?
                  • BorisShakhov
                    • Feb 2009
                    • 224
                    Because the old one was tightened up.
                    Now 1.3 max than down to 1 bar...
                      If you remove the small cap in the centre of the WG cap, you can adjust the WG spring seat down (or up).
                      • prj
                        • Mar 2010
                        • 6308
                        Of course not with stock injectors...
                          So why bring up 350 hp on an RS2 K24-7200 turbo when the topic is a K24-7000?
                          Just saying...
                          • prj
                            • Mar 2010
                            • 6308
                            Just saying...
                            Because OP said he is running 1.2 bar to redline, which is impossible on a K24-7000.
                            At least on a 2.2 liter.
                            • twenty valve
                              • Oct 2010
                              • 630
                              you just can't help yourself
