Help!
  • a25c
    • 259
    Help!
    Took off from lights wot,backed off after 200 yards and pulled into inside lane and then noticed the rev counter needle dropping to the bottom and ign lights come on.
    Car will not start so checked all the fuses at the drivers door,checked fuses under the bonnet and pulled all the relays in there aswell.
    I have vcds and what's strange is it can't connect to the engine module,all the other modules connect and there are no faults...
    Fuel pump?
    96 UrS6
    96 UrS6 Avant
    Previous:
    '87 coupe quattro, '85 90 quattro
    '95 S2 Avant '89, 200 quattro 1b
    '00 Allroad 2.7T, '02 S6 V8 Avant
    '96 A6 2.5 TDI quattro Avant.
    Back to basics, have you checked that you have fuel and spark?
    • DJones
      • Jun 2005
      • 2020
      Not sure on why it won't connect to vag com but I would check that a air hose hasn't blown off following your wot pull.
      Darren.
      • Monkeymagic
        • Mar 2012
        • 3419
        i agree with Alex check for fuel and spark first. does it crank over!
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          ecu fuses? check those too!
          • a25c
            • 259
            I opened the nut at the fuel filter and pulled out the pipe and no fuel on ignition lights or cranking,not sure how to check for spark....
            96 UrS6
            96 UrS6 Avant
            Previous:
            • a25c
              • 259
              yes it cranks over..
              96 UrS6
              96 UrS6 Avant
              Previous:
              • a25c
                • 259
                where might they be?
                96 UrS6
                96 UrS6 Avant
                Previous:
                  You need to sit down read this and follow all the hyperlinks it contains:
                  ECU fuse, etc. is above the ECU:
                  • a25c
                    • 259
                    I got the car recovered and its heading to Autowerks in Cork before I got to do anymore so I will update this when I know more..
                    Thanks to all who replied...
                    Robbie.
                    96 UrS6
                    96 UrS6 Avant
                    Previous:
                      Then you have no fuel pressure. Maybe the fuel pump has died a death, or you have an electrical problem that is preventing the pump running.
                      • AndyP
                        • 6049
                        Take the panel out of the boot floor to expose the fuel pump access panel, then get somebody to crank the engine whilst you have your head in the boot, you should hear the pump kick in. Sounds like it's dead though.
                        Also check the G28 engine speed sensor, the ECU will not start the pump unless it see's 25rpm from this sensor.
                        Paul's thread helped me last week when mine wouldn't start.
                        • benntenn67
                          • Jun 2009
                          • 859
                          Timing belt ??
                          Audi S2 Coupe 1995
                          VW Passat GL5 (hatch) 1986
                          VW Passat GL 1.8 (saloon) 1986
                          Carrera Subway 8
                            Originally posted by AndyP
                            ...Also check the G28 engine speed sensor, the ECU will not start the pump unless it see's 25rpm from this sensor. Paul's thread helped me last week when mine wouldn't start. http://www.s2forum.com/forum/showthr...ighlight=start
                            A25c: Be aware that the G28 engine speed will throw an error code (2111 (Blink Fault Code), 00513 VAG1551/2) if the engine isn't running when the VAG1551 (or VAG-Com) is used. This is a false code. All non-running AANs, ABYs and ADUs will throw that. The G28 is likely fine. And the RPM requirement is as low as 13 RPM:
                            Andy: I used Paul N's engine non-starting post as a basis for my more UrS4/S6 AAN-specific "Potential solutions to why your AAN-powered UrS isn't starting" post that I linked previously in this thread:
                            A25c: You might want to investigate the info in this diagram (all the labels are hyperlinks, just click on them, e.g. G6 Fuel Pump in the upper left corner)
                              Originally posted by benntenn67
                              Timing belt ??
                              Yikes. That would do it and cranking to try and start the engine would just bend the valves (more). Typically 2 intake valves, potentially more.
