Front pulley wobble?
  • audinut
    • Jul 2009
    • 2195
    Im being very nit picky with my s2 at the moment so im after some advice
    after doing my timing belt I noticed a noise at the front of the engine , it seems my timing cover is broken (the part behind the belt )
    So while I was inspecting this and deciding what to do I noticed the front pulley / vibration dampner moving ever so slightly as if its doing a little shimmy ? do they do this ??
    obviously im pretty nervous after just doing the timing belt (even though I have fitted thousands)
    The 4 allen key bolts are definitely tight and the main crank bolt was replaced torqued to 220nm and had 130-150 degrees put against it
    I know its supposed to be 180 but my 3/4 bar and extention tube (and the locking tool wouldn't have taken the last bit)
    any help gratefully recieved
    NOT a car dealer! just an S2/RS2 enthusiast
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Most I have seen wobble, I replaced mine with a new one and that still wobbles
    RS 2 580HP
    • andyg plym
      • Nov 2006
      • 4646
      Mine wobbled for years
      Also friendly advice for all but use lock tight !!
      • Acidburn
        • 13459
        I think I might have one of them covers you've broken.
        • Monkeymagic
          • Mar 2012
          • 3419
          dont they wobble due to the rubber vibration damper bit wearing. That said I bet if you put a new one on it will be the same anyway.
          • audinut
            • Jul 2009
            • 2195
            cover now repaired , and no longer fouling the belt !
