Ring gapping tool
    Ring gapping tool
    Thinking of getting one of these type of ring gapping tools. Has anyone got one or have any experience of them? Are they any good?
  • 90quattrocoupe
    • Nov 2003
    • 771
    I have been using mine for over 40 years, starting will my air cooled cars. Works real well.
    I found that after honing a cylinder, that the rings were real close to max gap. I would buy a set of the oversize top and second rings and then file them down to the minimum gap. That way my rebuild would last longer.
    I would put the ring in the cylinder, insert the ring less piston upside down to make sure the ring was square in the bore, and then feeler gauge the gap. I would file down a little at a time and check gap often.
    This is also a good way to check how even the bore is on a cylinder. Put in the ring at various places on the bore and check the end gap.
    Greg W.
    • Tony Stark
      • Nov 2009
      • 288
      I looked into getting one, but the S2 had used enough money already and i probably wouldn't use it again for a long time.
      From what i understood the the ring material removed must be by filing from outside to the centre. And make sure the ring ends are square to each other like this ||
      So i bodged(?) this together.
      Aslong as the file seat in the wood is a good fit.
        Cheers guys, I will get one
        • AndyP
          • 6049
          I have the same one, I'm sure I payed more than $30 for it though
          You can borrow it if you want?
            That would be ace Andy
            I don't need it just yet, but if i can borrow it in few weeks that wold be much appreciated
