Water temperature issue
  • vcosmin
    • Apr 2008
    • 644
    • Country: Romania
    I have a problem with water temp, on analog gauge is around 80/85c , but on climate control diagnostic is not going over 50c, changed the sensor from back of head,but still the same. Some sugestions.
  • valjo
    • 1110
    • Country: Latvia
    sensor in head is only for motronic. check multifunctional sensor on wather rail under the intake mainfold .....
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
    • vcosmin
      • Apr 2008
      • 644
      • Country: Romania
      Well, acording to this http://www.sjmautotechnik.com/troubl.../20vmfsns.html
      is only for analog gauge, which is working fine. I was thinking that the diagnostic utility from climate control, display the same data that ecu is receving ?
      • pasbogdan
        • Sep 2009
        • 1160
        • Country: Romania
        Did you managed to check resistance of the rear sensor?
        temp vs approx resistance
        40c 1200 ohm
        60c 600 ohm
        80c 300 ohm
        100c 180 ohm
        If gauge works fine and coolant is really approx 85-90c you should not be able to hold your hand on the upper cooling hose.If that is happening check the resistance of the rear sensor.
        Hope it helps.
        Check also temp that ecu sees with diagnostic tools to confirm climate temp is what ecu sees.
        • vcosmin
          • Apr 2008
          • 644
          • Country: Romania
          Just checked witch vagom, temperature is fine, probably is a problem with Climate Control Sensor.
            Climate control temperature sensor info
            This info is related to the AAN but will likely be close to what you need:
            Note: For RHD C4 UrS4/S6s, the climate control temp sensor is part of the climate control heater valve, not a separate part.
