Turbo oil return removal
  • Cymru1
    • Sep 2008
    • 436
    Just a quickie...
    Just going under the bonnet tommorow to change plugs,
    general clean, etc. Wondering if its an easy job to remove the return
    pipe (access issues?) Thought id take it off to make sure its
    clear (some smoking issues!) so I could tick it off the list.
    Had a quick search but couldn't find the post I seen before explaining
    how to get to it.
    Cheers.
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Originally posted by Cymru1
    Just a quickie...
    how to get to it.
    Cheers.
    It's simple, the size of the return pipe is a big diameter so recon it will never be blocked, I took mine off once was told the same
    Jack the car up 2 Allen keys n the bottom of the turbo I used a socket with long extension ,if its got air con theres a bolt holding it to the block
