MFTS what causes failure?
  • Rikki Kitto
    • Feb 2010
    • 6276
    Had issues with this so replaced but replacement seems to have packed up to. Is this coincidence because of using old parts for replacement or maybe something else causing failure? I was thinking of buying a new one but at £125 the last thing I want to do is fit it and a recurring problem kills it
    Any ideas what might be killing them off?
  • driftin jo
    • Sep 2007
    • 2222
    I would say you will only get so much out of a second hand one as it
    is heat cycles that kills them so they only have a finite lifespan.
    Are you sure its not just a wiring problem/ bad connection that is
    temporally fixed when you change it?
      Originally posted by Rikki Kitto
      Had issues with this so replaced but replacement seems to have packed up to. ...Any ideas what might be killing them off?
      Probably they are fine. Replacing used with used isn't necessarily a guarantee of no problems. *IF* they are failing, it's either the internal electronics (broken connection?) or the external wiring. I would suspect the external wiring before the actual MFTS.
      MFTS info:
      • Rikki Kitto
        • Feb 2010
        • 6276
        Cheers guys will be much cheaper to fix bad connections so fingers crossed
