Just looking at what's needed to convert an AAN engine to ABY spec. We know from this thread and this thread and this thread.
Ignoring the cylinder head for the minute and off the top of my head...
Anything else?
I'd like to compile a list of things needed to do the conversion, as it'll be a useful resource
Obviously most of the metal bits are on the car, but it's things like gaskets,. nuts bolts etc. that would be required to do a smooth conversion.
- Front pulley and damper
- Flywheel
- Engine mounts, incl. snub
- Sump
- Breather system (this isn't an issue for me but will be on a stock car)
- PAS pump, belt and bracket
- Water manifold
- Cam cover (breather return outlet is different but can be swapped)
Anything else?
I'll be fitting a lightened 3B / 7A or Ally one, depending on how brave I'm feeling, along with a new clutch.
My conern with my AAN to ABY spec engine conversion was the balance, so I took the decision to open it up and do it all once and for all. I guess if you need the car every day that changes matters somewhat.
