How to test pressure regulating valve?
  • Spidey
    • Oct 2008
    • 134
    • Country: Lithuania
    Yesterday I tried to check all hoses and find a boost leak.
    Changed two hoses.
    Then tried to make a boost leak test one more time.
    And then I heard noise coming from pressure regulating valve. Removed, cleanedi it, but I still hear that noise. It comes from a small hole. It is ok?
    Maybe it's possible to check this valve?
  • Monkeymagic
    • Mar 2012
    • 3419
    pretty mauch the same part as on my old mk2 golf. That does not leak at all.
    • VagOrBust
      • Feb 2010
      • 107
      • Home: Netherlands
      Changed two hoses.
      Correct me if I'm wrong, but afaik at this pressure regulating valve there shouldn't be any positive pressure at all since it's part of the crank case ventilation system. There should be a one way way valve between this part and your air intake that blocks the airflow if your engine is making boost. And you need to plug the crankcase ventilation system's connection at the air intake hose before the turbo when pressure testing.
      5 cilinder addict:
      1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
      1993 S2, 2.2 turbo, ABY, long term project.
      2006 Ford Fiesta 1.4 TDCI. Because reasons.
        ... It comes from a small hole. It is ok?
        Maybe it's possible to check this valve?[/IMG]
        I think you have a leak in the diaphragm of the pressure regulating valve. I think that the tiny hole is there to allow air in and out of the upper diaphragm chamber. However, under a boost test no air should be leaking out of that hole.
        PCV system info: http://forums.quattroworld.com/s4s6/msgs/22506.phtml
        • ash2050
          • Jun 2012
          • 255
          Mine leaked in the boost test from the same place you mentioned.
          The diaphragm must be split inside.
          I got a new one from dealers around £18 and no leaks!
          • Spidey
            • Oct 2008
            • 134
            Thanks for the replies guys! I'll change it
