Anyone?
Technical advice on mis fire on 2.0 tfsi engine!!!
Bit of an update on this the car is making 13.8 psi boost. But is requesting 16.7 according to logs.
Stock is 13/14 psi on this engine so i would suggest it is mapped.
However I have cleaned the inlet manifold, ports and inlet valves up and the car is a lot smoother hasn't logged any misfires (yet) and since finding a small leak on the o ring for the MAP sensor I have not managed to get the under boost code to come back.
I hope this is it for this car.... I also hope it helps someone out. Steven.Comment
Good stuff I'm glad things are going your wayBit of an update on this the car is making 13.8 psi boost. But is requesting 16.7 according to logs.
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Just hope it stays that way.!!! Its my mates car but its put me off having one of these engines. It is bloody quick though.
The best bit is the mpg has gone from roughly 23 mpg to between 38 to 40mpg.Comment
