UR quattrro misfire
  • audinut
    • Jul 2009
    • 2195
    ok i didnt have time to get the bore scope out , the lifters go up and down with the engine turning , they kinda feel/seem the same , it was blowing blue smoke when it came in
    its definately a burnt out or bent valve as i cant see it being melted rings or a hole in the piston
    NOT a car dealer! just an S2/RS2 enthusiast
    • LSG
      • May 2010
      • 897
      Can you do a leak down test. ? Do you have a tester or would you like me to pop one over to you. Also has the cylinder been bore washed ? This could also give you low / no compression.
      • audinut
        • Jul 2009
        • 2195
        yea good plan and thanks for the offer , im pretty sure theres a leak down kit in the workshop
        i would have thought a washed bore would still give me a small reading ?
        • Ian Simmonds
          • Jun 2005
          • 2858
          Ours, about 15 years ago, had loss of compression and it turned out to be a slipped valve seat partially holding the valve open.
          93 MTMS2 Avant
          • chezz
            • Apr 2007
            • 440
            maybe a valve collet has slipped and jammed the valve...take the cam out - you don't need to remove the head to do this and examine the valve /spring/followers ...something physically has to be causing this problem.
            • stocious
              • Jul 2012
              • 838
              Get some compressed air in the cylinder if nothing is visually apparent and have a listen. It should be a loud leak if zero compression .
              1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
              • adam g
                • Feb 2007
                • 445
                Hmm, blue smoke could mean holed piston or head gasket gone. Agree a hole in piston is unlikely unless it is tuned or modified ecu.
                • audinut
                  • Jul 2009
                  • 2195
                  compression test results
                  cylinder 1 - 100 , cylinder 2 - 95 , cylinder 3 - 75 , cylinder 4 - 35 , cylinder 5 - 0
                  headgasket anyone?
                  • s2driveruk
                    • 12696
                    thats odd...the compression test shows consistent leakdowns from 1-5...not sure i've ever seen that before?
                    1992 3b S2 Coupe
                    • Ian Simmonds
                      • Jun 2005
                      • 2858
                      Almost as if the head hasn't been screwed down properly one end...
                      93 MTMS2 Avant
                      • audinut
                        • Jul 2009
                        • 2195
                        mmm I know , if you want me to make it even more odd , how about this it was stored for 7 years , current owner bought it and took it to dialynx who replaced the fuel system there advice was to drive it once a week , he hasn't and has just stored it and occasionally started it .
                        the other day when he collected it he said it started fine and drove with no misfire for at least 15-20 mins (he thought he had a fuel issue as it had been in the tank for so long) he then said it started messing around after that.
                        so from no misfire to the compression readings I have now
                        • s2driveruk
                          • 12696
                          yeah exactly, normally you have a few at very similar pressures and one or more fluctuations. Like that as you say Ian, looks like its not on properly.
                          1992 3b S2 Coupe
                          • Ian Simmonds
                            • Jun 2005
                            • 2858
                            Just a thought, but after 20 minutes the whole block/head etc will have expanded and be hot. Maybe it was seven years of stone cold inactivity followed by this heat cycle that's freed up the head studs.
                            93 MTMS2 Avant
                            • stocious
                              • Jul 2012
                              • 838
                              headgasket anyone?
                              what happens when a wet test is done, just out of interest ? looks like there something to be learned fro this, thanks for posting comp results ect..
                              just had thought, does the oil stink of petrol by any chance ?
                              • audinut
                                • Jul 2009
                                • 2195
                                i havent had a chance to check but i will tomorrow
