B4 v6 to 2.7 BI turbo conversion?
  • Gavin A
    • Nov 2012
    • 260
    Does anyone have info on fitting a B5 S4 engine/loom to a V6 2.6 80?
    I have seen a few pics of cars done and I have an engine.
    If anyone can point me in the direction of a build thread that would be good!
    Im wondering if room needs to be made in the chassis legs for turbos.
  • audinut
    • Jul 2009
    • 2195
    wouldnt it be easier to run a big power 5 pot?
    NOT a car dealer! just an S2/RS2 enthusiast
    • Gavin A
      • Nov 2012
      • 260
      Yes it would, but I have a V6 80 and an S4 engine.
      • audinut
        • Jul 2009
        • 2195
        sell the s4 engine and start a much easier project
        • Gavin A
          • Nov 2012
          • 260
          Anyone know this car?
          • sam80quattro
            • Oct 2006
            • 1496
            pretty sure ive read in the past that the turbos do need to be where the chassis legs are.. good luck on going a different route to the norm
              Yes you will need to make a few structural changes, but nothing too strenuous.
              I say go for it, it would be nice to see something a bit different to the norm. If I was to stray from the I5 this is what I would do
              • audinut
                • Jul 2009
                • 2195
                dont get me wrong , IMO i just think its a lot of work and probably cash for the end result .... wish you the best of luck though
                  For sure, but he has an n/a V6 car and an engine already, so actually the Bi-turbo is probably a much cheaper route to 300hp, albeit a less plug & play job
                  • mle
                    • May 2011
                    • 23
                    There is a topic in audifinns: http://www.audiclub.fi/audifinns/sho...d.php?t=119518 - Lot's of hopefully helpful pics. Maybe Google translate can help you with texts.
                    80q Competition 1.8t
                    • audinut
                      • Jul 2009
                      • 2195
                      i take it the v6 box will bolt up to the 2.7 engine with no issues then?
                        yup, the V6 uses a different final drive ratio but will bolt right up and work well as long as it can handle the torque in the longer term, in fact the gear ratios are probably really well suited for this nice torquey engine
                        • audinut
                          • Jul 2009
                          • 2195
                          just a wiring fiasco then? bonus
                            yeah there is that
                            • Gavin A
                              • Nov 2012
                              • 260
                              Thanks for link and input chaps.
                              It does look to be a bolt up job on the box, and I think it will break traction before stressing the box. (yes, im building a FWD cabrio with 300hp)
                              The wiring doesn't scare me, but the chassis legs does. Im also thinking I can run a throttle cable instead of fly by.
