RS2 turbo
  • RoadKill
    • Dec 2004
    • 567
    RS2 turbo
    done a full rebuild but the oil feed and return was lecking niped them up and snapped a bolt in the bottom side , drilled and taped it out put in pull the thred out
    can the houseing from a standed turbo be used to rebuild it ?
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
    K24-7000 and 7200 info
    Originally posted by RoadKill
    ...can the houseing from a standed turbo be used to rebuild it ?
    I don't think so. Have a look at this: http://12v.org/urs/UrS4dotComTurboFAQ.pdf
    Which is a link out of this: http://forums.quattroworld.com/s4s6/msgs/211339.phtml
    Which also contains this: http://12v.org/urs/RS2%20Turbo%20Dis...by%20twoqu.pdf
    • twoqu
      • Sep 2003
      • 3103
      Just get a thread repair kit and insert it!
      • gavs20v
        • Sep 2004
        • 3057
        helicoil?
        S2 Cabriolet.........
        • RoadKill
          • Dec 2004
          • 567
          shows the part number for the rs2 Bearing Housing K26 D75/51/41 (CHRA) 5326-150-0026
          just need to find the standed S2 one
          S2 ABY
          B8.5 A4
          • RoadKill
            • Dec 2004
            • 567
            trying not to use a helicoil but if needs must ,
            S2 ABY
            B8.5 A4
            • twoqu
              • Sep 2003
              • 3103
              If your turbo is sound seems a rather drastic solution to dismantle it, risking possible damage to the components. For example do you know the correct torque for the nut?
              Even if you had to take it somewhere to get a timesert if you have made the hole oversize, thats less risky in my opinion.
              Would think its perfectly acceptable to use a thread repair to hold the drain pipe on. Its not under pressure like the feed.
              • RoadKill
                • Dec 2004
                • 567
                fixed it with a thread repair kit , seem to have stoped lecking with new gasgits
                S2 ABY
                B8.5 A4
