The sensor beside the front pulley at the oil pump, what is it and what part no?
Its doing the usual VAG sensor trick and leaking oil through the middle.
I was under the impression that oil pressure and temp were monitored from the sensors by the radiator.
Its an ABY.
My oil temp sensor is leaking into the rubber hood of the eyelet connector that connects to it. Not to bad at the moment though. keeps the connector rust free. :0p
The sensor beside the front pulley at the oil pump, what is it and what part no? Its doing the usual VAG sensor trick and leaking oil through the middle. I was under the impression that oil pressure and temp were monitored from the sensors by the radiator. Its an ABY.
The oil temp sensor is on the oil pump as Eric (IrishS2) has pointed out. Here is more info about the Oil Temp sensor:
