Crankshaft pulley(timing) failure
  • Tesa
    • Nov 2011
    • 67
    • Country: Czech Republic
    Igor : It happens I told you, that I'm like magnet for disasters :-) Today I'll use better endoscope and next week I'll take head off, so I see what's damaged. Then I will use you experience to repair it in short time :-)
    • filip.krticka
      • Sep 2008
      • 170
      • Home: Czech Republic
      I'm really interested in this tread, my engine built is nearly finished and I have used OEM wheel and tightened it using vag tool two days ago. I'm running on RS2 upgraded output and don't want to suffer for exactly same issue.
      What shall I do?
      • GazzaG60
        • 4133
        it all depends on pulley condition before you refitted it.
        I refitted the same I took off when I did mine. I then ran a fair bit more than rs power and had no issues.
        a good pulley will do big output the same as small output
        • rs200
          • May 2009
          • 1398
          • Home: Croatia
          I spend to much time and money on that engine. I look for every piece , every whole, bolt, gaskets, everithing must be and it was perfect when I collect that engine together.
          every bolt which I have in my hand was tightened by specific Nm .
          I thing that only precaution of this kind of failure is:
          tnx to Thuppu for link.
          • Tesa
            • Nov 2011
            • 67
            #20
            Hello,
            Just repaired everything, and the car is running as it should run. I wasnt that expensive failure, but a lot of work...
            Thanky everybody for support.
            Radek
