aux rad delete hoses
  • stocious
    • Jul 2012
    • 838
    what are my option or what have people done with the hoses when one removes the aux rad, is the new hoses i can buy ? or do people just cut them back and block them ?
    Steve
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
  • Sonic
    • Jul 2006
    • 5514
    Cut and block.
    S2Forum.com Administrator
    • stocious
      • Jul 2012
      • 838
      Originally posted by Sonic
      Cut and block.
      ok, cheers, was wondering would the little stubs left trap air, probably being paranoid
      thank you
      • K Simmonds
        • Dec 2007
        • 7627
        You can use the main hose from a 10 valve Coupe and just blank the rad with a short bit of hose and a big bolt. If you want to do a really tidy job use the rad and hose from a 10V, that's what I've done. Blanking the pipes works just fine though.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • stocious
          • Jul 2012
          • 838
          ill look into a 10v hose, good idea thank you,
          • sidrick
            • Jan 2011
            • 1342
            I have one for sale if you can't source one locally
            **Edit: Could maybe arrange to drop it off with FRED if you're buying that airbox from him
            • stocious
              • Jul 2012
              • 838
              Pm,d , thanks
              • DEREKCO
                • Feb 2009
                • 435
                Hi I just went to a local plumbers and got 2 blanking plugs and fitted them just in case I wanted to refit the aux rad .
                • stocious
                  • Jul 2012
                  • 838
                  pm.d you about paypal details, pm them to me and ill send the money,
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    I also used copper blanking caps.
                    I fitted them inside out, to mess with people. I got quite a few comments on my coolant hoses with open ends.
                    SS
                    • Rusty
                      • 18953
                      Don't forget I sell black anodized blanking plugs
