As per title the old girl is doing my head in at the mo what with battery drain/ boost leaks and other niggly bits.
I did a boost leak test again on Sunday and found that the hose from I/C to throttle body had came off the I/C side so put it back on checked all the clips did a test found a small leak from the back of the boost gauge i have just fitted fixed that tested again no leaks opened her up on Monday everything fine coming home tonight over taking a car and started kangarooing up the road not even full throttle, how embarassing when im on the outside overtaking and the guy looking at me stupid. I can't figure out why one day fine and the next not. Drives ok when normal driving.
My son is going to Vagcom the car on Saturday what i need to know is what to look for when doing a live log on the maff and also for the boost what sort of figures do i need to look out for. we are both new to vagcom so are still learning. Any input from the tech guys on here would be most welcome.
What spark plugs do you use?
