Is there a way to thoroughly clean the rust scale inside the coolant pipes or some kind of chemical soak that would loosen it up? Trying to get through the bends in the smaller diameter hoses would be a pita. These are silicone hoses, so I do want to re-use them.
Removing rusty residue in silicone coolant hoses?
yes,
i have done this before Pat.
you can use a snake like tool, depends how small they are but it is a piece of very pliable wire that has a memory and quite rough bristles on the end. i think they are actually used to clean brass instruments
i used brake cleaner on the inside, not sure if this is a good idea but it worked well. -
Here is the link for the Plasma dials you were after
http://xtuners.com/shop/Plasma-dials...de-Plasma/Audi
ABY S2 stroker (work in progress)
B5 1.8T quattro
B4 2.3 (decommissioned)Comment
legend!Here is the link for the Plasma dials you were after
http://xtuners.com/shop/Plasma-dials...de-Plasma/AudiComment
