Does anyone have a figure on the valve to piston clearance on a stock engine (3B / ABY) with stock cams?
Alex
Alex
but no concrete figures. There is a guy on Classic Audi who is also using Wossner pistons and I think is planning to check this dimension. Otherwise I will just get my block decked to level it, get it bored and then to a dummy build-up and check it with blu-tac or the like. Then I can get more machining done as required. Just means more trips to the machine shop!
