VCDS measuring blocks
  • bilko0795
    • Feb 2011
    • 1883
    I am trying find which block to use to test the Maf and I can't find it. I have looked on s2 central but it doesn't seem to say which one or if you can test the Maf I remember someone on here saying that they tested their Maf using vcds could someone point me in the right direction.
  • mcandmar
    • Apr 2004
    • 5118
    As far as i know you cant see the MAF or MAP sensor readings via vagcom. Only seen that level of functionality on newer 4cyl 20v motors.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • bilko0795
      • Feb 2011
      • 1883
      Ok thanks
