Bosch 044 Fuel pump help needed
  • andyg plym
    • Nov 2006
    • 4646
    Dave what about all the different part numbers in post number 5 ? This is where my confusion lies.. Going to see if I can get one from my local bosch dealer in town and get at trade price
    • Kieron20V
      • Mar 2008
      • 1505
      They're all different part numbers...
      They have the same beginning, but different suffixes, a 040 is an 040, an 044 is an 044. Its called an 044 because that's the part number.
      None of the other 4 part numbers you posted end in 044.
      Sent from my HTC One X+ using Tapatalk 2
      1994 URS4 Avant RS2+
        There is only one "044" pump in your list. The last one.
        Bosch 910 pump is 200 litres per hour and supports 450 bhp at 73.5 PSI # 0 580 254 910
        Bosch 975 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI # 0 580 254 975
        Bosch 984 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI # 0 580 254 984
        Bosch 040 pump is 235 litres per hour and supports 520 bhp at 73.5 PSI # 0 580 254 040
        Bosch 044 pump is 330 litres per hour and supports 730 bhp at 73.5 PSI # 0 580 254 044
          Originally posted by Kieron20V
          They're all different part numbers...They have the same beginning, but different suffixes, a 040 is an 040, an 044 is an 044. Its called an 044 because that's the part number. None of the other 4 part numbers you posted end in 044.
          I don't understand Andy's confusion.
          • speeding-g60
            • Aug 2008
            • 1186
            not that i can help much.
            but true 044 pumps have the part number ending in 044. and BEWARE the fakes. they have different sized fittings.
            i run two REAL 044's in my car, and they do quite well even on E-98 almost pure ethanol.
            i get them from this place, www.looseboltsmotorsports.com
            how to spot a fake:
            Rotary Car Performance - BOSCH 044 real and knockoffs --read this-- - I just wanted to let everyone know that in addition to knockoff wastegates, blow off valves and turbos we can add Bosch 044 fuel pumps to the list. Someone recently bought a pair of 044 pumps from a fellow forum member and the pumps looked different...
            • jaychen
              • Jun 2013
              • 269
              • Country: Australia
              #21
              Great links speeding-g60.
              There were a HEAP being flogged off locally in australia at one point, needless to say one guy had a lot of people knocking at his door not long after.
              • jaychen
                • Jun 2013
                • 269
                #22
                Can anyone get the strainer and basket cheaper than $180?
                • Pat D
                  • Dec 2011
                  • 748
                  #23
                  how to spot a fake:
                  http://www.rx7club.com/rotary-car-pe...s-read-959132/
                  Curious about your set up speeding-g60 as I'm not sure which pump to use, what base pressure do you have on your set up and how much boost?
                  ABY S2 stroker (work in progress)
                  B5 1.8T quattro
                  B4 2.3 (decommissioned)
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    You'll find them in the tank of 10V coupes as well as 100's/200's if that's any help.
                    1990 B3 2.0 80 quattro.
                    1992 C4 2.8 Avant quattro
                    1994 MTM RS2.
                    1998 B5 TDI quattro Sport.
                    2000 B5 TQS.
                    • jaychen
                      • Jun 2013
                      • 269
                      #25
                      Thanks mate
