As I understand it, the MFTS provides 2 functions: the first is to supply the cluster with a temperature and the second is to provide an over-temperature cutoff when coolant temps exceed 120degC.
Are there any more functions?
I've had a bit of a thought about ditching the extortionately priced item and replacing it with either just a temperature sender and thus sacking off the water temperature boost cut function that any driver who looks occasionally at the gauge could do themselves, or with the addition of a secondary warning light / thermo switch to do the job.
So, is there a temperature sender that has the same resistance profile as the MFTS?
