pictures of fuel setup on s2 coupe
  • powercar
    • May 2008
    • 93
    • Country: Norway
    i'm looking for Pictures from fuel setups on s2 coupe With double 044 fuelpumps in original fueltank and With original fuelrail without original fuelpressure regulator.
    if someone could help me With this i would be very grateful
    IG: Alb garage
  • powercar
    • May 2008
    • 93
    • Country: Norway
    nobody have Pictures of this?
    IG: Alb garage
    • djh
      • Jun 2011
      • 1622
      on a coupe I very much doubt you will get two 044 pumps in the tank. you could have 1x lifter pump in the tank then 2x 044's externally fitted (will be noisy if inside the car)
      Some avant owners have fitted 2x pumps in the spare wheel section.
      • powercar
        • May 2008
        • 93
        • Country: Norway
        no problem to fit 2 pumps in the tank, but i just wanted to see witch solution People had choosen for this if they have 2 pumps in the tank.
        here is a Picture of how one her in norway have done it
        IG: Alb garage
        • powercar
          • May 2008
          • 93
          • Country: Norway
          Anyone have some pictures? :-)
          Sent from my LT25i using Tapatalk 2
          IG: Alb garage
          • S2SE
            • Mar 2012
            • 91
            Dont have them in My tank but heres a picture of my installation in the back of my coupe:
            Bilder på tomas124s bil Audi S2 Coupé Quattro "2.5L" (1991) (Bild av 20)
            Doesnt actually make much noise when i have the shelf in there
            • powercar
              • May 2008
              • 93
              • Country: Norway
              Nice setup you have there
              But one of the reason i want to install them in the tank is because the build is suppose to look as original as possible, "a wolf in sheeps clothing" if you will
              IG: Alb garage
              • S2SE
                • Mar 2012
                • 91
                Thanks
                I understand. I wanted to keep as much of the interior as possible when i did this. Keeping it as clean as i could with black an fittings and nyloncovered lines. Because of the catchtank I never even thoght of hiding the pumps either.
                • powercar
                  • May 2008
                  • 93
                  • Country: Norway
                  No problem to fit a hidden catch tank inside the
                  tank also, or somewhere else in the back :-)
                  Sent from my C6903 using Tapatalk
                  IG: Alb garage
                  • powercar
                    • May 2008
                    • 93
                    • Country: Norway
                    Here is my setup that i have started on now, not completely finish yet, but a good start.
                    The filters are mounted at each pump in the bottom for best possible suction to each pump, also i had to cut off some off the length to the filter adapters to make it as short as possible, i don't have a Picture of this
                    IG: Alb garage
                    • A1QSHIP
                      • Aug 2004
                      • 975
                      Where did you source the fuel pump inlet filter?
                      "Nulla tenaci invia est via"
                      • Mcstiff
                        • Oct 2004
                        • 504
                        Looks like Sytec; maybe http://www.glencoeltd.co.uk/bosch-05...nc-dowty-seal/
                        1995 1PissedOff90sigpic1991 USDM CQ 7aT
                        • powercar
                          • May 2008
                          • 93
                          • Country: Norway
                          it's sytec like mcstiff said
                          IG: Alb garage
