Maf question
  • stocious
    • Jul 2012
    • 838
    Maf question
    I have received a maf, as the wire in my original was broken,
    Looking at the two side by side, there almost identicle, numbers match ect..
    But on the one that was on car when I bought it, when looking at the plug, just to the left of it there is a recessed brass screw, wich looks like it had a cap over it, anti tamper cap I think ?
    One of my first post on here was asking if the maf,s were adjustable/calibratable, because of the screw
    Got an answer of no, so I thought no more of it, but seeing the one that I have to fit now, which does not have the screw, I'm curious as to the purpose of it if anyone can help ?
    Also can I use carb cleaner to clean it ?
    If I can get my head around windows 8 I'll post a pic if someone wants to see the screw mentioned !
    Steve
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
    Windows 8 is toss Get classic shell and then you can run it from the desktop like win 7 and before.
    • stocious
      • Jul 2012
      • 838
      Cheers for the tip !
      Toss is about the only thing I have not called it yet this morn
      Any idea about the screw rusty ?
      Or if carb/intake cleaner is safe for hot wire mafs?
      • stocious
        • Jul 2012
        • 838
        heres the screw in question
        • prj
          • Mar 2010
          • 6308
          If the screw has been tampered with the MAF is useless and it's readings as well.
          • stocious
            • Jul 2012
            • 838
            cheers PRJ,
            i never went at the screw, but im positive that it has been tampered with before, the car had some serious boosting issues when i bought it..
            makes alot of sense now thanks..
            the one that i have now, does not have the screw..
            whats your stance on using some wynns arosol carb cleaner on the maf im going to fit..
            with screens or without, sorry for all the questions
            • mcandmar
              • Apr 2004
              • 5118
              I believe the screw is for calibration so don't mess with it. It was only on RR and 3B engines as far as i know. Carb cleaner should be fine, just hold the can at a good distance so you dont blast the hotwire out of it, but if it aint visibly dirty leave it alone.
              Windows 8 isnt bad when you get used to it, infact as an OS its the best yet, its just the user interface that could do with being finished. For example it took me a while to figure out where the power menu was hidden to shutdown the machine. Crazy when i an IT engineer using Microsoft products since Windows v2 couldn't figure that out, had to resort the old ctrl+alt+del menu. I mean how did that get past usability testing
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • stocious
                • Jul 2012
                • 838
                haha.. funny that as it took 2 people here to turn it off
                cheers for the info on the MAF, im nearly sure when i asked that question originally people thought i was a bit daft lol..
                full circle now and all is clear and i will give the replacement maf a clean with the stuff.
                its looks ok, just want to do what i can before i whack it all back in
                cheers
                • mcandmar
                  • Apr 2004
                  • 5118
                  I usually don't advise people to clean them as it can cause more problems. Only reason i would ever clean one is if the car ran with a K&N filter and built up a layer of oil on the wires. Under normal circumstances it shouldn't be needed as the MAF has its own self cleaning routing.
                  • stocious
                    • Jul 2012
                    • 838
                    ill be very carefull, there is a coating of oil within the maf itself, which could be from a oiled filter...
                    while im on the subject, plugging in the maf turning on and off the ignition and watching the wire, i should see the burn off right ?
                    probably a question answered to death but is there a set amount of time the ignition has to be on ?
                    or does it have to be started first for a burnoff to occour ?
                    thanks
                      G70 Mass Airflow (MAF) sensor info
                      I usually don't advise people to clean them as it can cause more problems. Only reason i would ever clean one is if the car ran with a K&N filter and built up a layer of oil on the wires. Under normal circumstances it shouldn't be needed as the MAF has its own self cleaning routinE.
                      When the engine is turned off, the holding relay in the ECU provides power to the MAF hot wire for 5 seconds to burn off the crud. This is discussed in this MAF post:
                      I have a spare 471K MAF in my hand from my Oct. 92 built 93 UrS4 (I am running an RS2 MAF). It has the calibration screw (but it is still behind the tamper-proof plug (never touched)).
                      • stocious
                        • Jul 2012
                        • 838
                        cheers
                        ill have a good read of that now..
                        • stocious
                          • Jul 2012
                          • 838
                          Gave it a clean, it was very dirty, looks like new now, fitted along side a fresher ISV, and I must say she sounds smooooth
                          Cheers for all the help/info lads
