ABY injectors on 3b
  • audiman
    • 4827
    Some ppl say only use the bosch one, but NTK~(NGK) make a very good lambda sensor. I fit NTK ones to my customers car and have never haed any problems with them. Cost of a universal 3 wire sensor is about £20-25. These can soldered onto the original wiring and work just fine.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Mihnea
      • 1288
      @billman: this is the sort of question you can ask any VAG dealership/Bosch Service center...
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • Erikb
        • Jul 2004
        • 648
        I replaced my lambda 3000 km ago, also the spark plugs, wgfv, WG seal, new spark plug cables, checked for boost leaks, fuelfilter, new thermostat, cleaned maf, new airfilter,new dump valve, new vacuum hoses, cleaned ISV (the idle valve), etc.
        but still has the starting problem, maybe it is the fuel pump or one of the sensors?
        Getting everything sorted out for my 5++ hp project
        • Erikb
          • Jul 2004
          • 648
          Can the starting problem be occured by the hall sender. I read some threads about the hall sender. Most of the time the car wont start when it is hot, mine wont start if it is cooled down. Besides that when I crank and shutt down the engine it doesnt sound right, it sounds if something is out of line/balance, the car shakes a bit.
          Can the hall sender be tested easily?
          thanks
          • Billman
            • 4129
            #20
            I had a prob with the hall sender and the car would not start with the engine hot!
            Greetings
            Go Holset or Go RS4
            • Erikb
              • Jul 2004
              • 648
              I only read threads that cars dont starrt when they are hot, min does start well when it is hot or completly cooled down, but is hard to start when it cooled down for an hour ->2hours.
              • audiman
                • 4827
                Erik, these hall sender problems are normally only ABY cars. But the 3B has a hall sender in the distributor. They will play up and not make the car start no matter how many times you crank the engine over. I suspect it may be something else IME
                Audi UR Quattro
                • Erikb
                  • Jul 2004
                  • 648
                  Yeah I think you ar right audiman. Just pickep up my injectors, a company nearby cleaned (ultrasoon)them. They said it was necessary, they replaced a lot of stuff, some things on the top side and also replaced parts on the underside, it has now a yellow plastic cap on the underside.
                  I will fit them tonight
                  nice carpet dont you thinnk
                  • audiman
                    • 4827
                    Real nice!! LMAO
                    Hope they sort out the problem dude
                    Audi UR Quattro
                    • Erikb
                      • Jul 2004
                      • 648
                      fitted them, car runs fine. Havent tested the starting problem. It has to cool down first.
                      • audiman
                        • 4827
                        Hopefully it will be OK. How long do you have to leave it??
                        Audi UR Quattro
                        • Erikb
                          • Jul 2004
                          • 648
                          approximate an hour
                          • Tommy200rs
                            • 285
                            #28
                            did you get a measurement report done with 3bar flow presure for each injector ? how much was the delivery
                            amount within certain measuring time ?
                            Official specs delivery values of 3B injectors can be read in
                            Bentley Official factory repair manual Audi 200. -89-91
                            Official specs delivery values of AAN injectors can also be read in Bentley Official factory repair manual Audi 100 S4.
                            Book or cd rom from
                            Audi 100, 200: 1989-1991 Repair Manual. including 100 Quattro, 200 Quattro, Wagon, Turbo and 20-valve models. by Audi of America · Three volume set: 1,731…
                            • Erikb
                              • Jul 2004
                              • 648
                              No I totally forgot to ask a sheet . When I brought the injectors he asked for what kind of car they where. He told me he had a book inwhich the official specs where written. When I picked them up he said that they where tested afterwards and that they now meet the specs. So I hope/trust that it is right now.
                              When i started the car this morning (freezing at the moment) it started right away, in a second. But still have to test it when it is cooled down.
