Battery and additional eart point suggestions
  • stocious
    • Jul 2012
    • 838
    Looking for suggestions for a new battery, what rating should it be ect..
    Also I'm going to put an additional earth strap from the battery but can't decide where to?
    Bell housing
    Intake manifold
    Cylinder head
    Considering the type of ignition on the 3B and spark hop/cylinder pressure being its weakness, as close to the plugs as possible is the best location. ? Or not ?
    Stephen
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
  • AndyP
    • 6049
    I use the Bosch S5 battery and I've also run a 2nd earth strap from the battery to the bell housing. The car was slighty sluggish to start even after I'd cleaned the earth strap on the drivers side, after adding the 2nd strap the starter was spinning over much quicker.
    • stocious
      • Jul 2012
      • 838
      Cheers andy I'll look into a Bosch one
        in the end i've ended back up with Bosch S5 batteries, they are cheap from eurocarparts or ebay
        • AndyP
          • 6049
          This is the one I have:-
          Don't pay this price though, wait until they have one of their 25/30% sales!
          And when I say 'I' fitted the extra earth cable, it was actually Brian Tonks, so credit where it's due
          • stocious
            • Jul 2012
            • 838
            Cheers for all the help/suggestions lads
            Laid out atm but ill get on it once fit again
