Pic Request - ABY T8 connectors
    Can anyone help me out with some pictures of the T8 connector bracket in a RHD ABY or RS2 engine bay? I need to weld in the studs to mount this as they are no present in my coupe, want to make sure I put them in the right place.
    Alex
  • irishs2
    • Apr 2009
    • 2455
    If you put the studs in the correct place you will have to cut the bracket (or drill 2 holes) to get it to fit with the vacuum servo, I have included many pics, you might be able to average the error.
    Eric
    95 S2 Avant under rebuild.
      Thanks mate
      It was the location of these two that I needed, luckily the other two for the bracket were already there and used to support the coil on the 7A/3B.
      I already cut & welded the other bracket like you did
      • irishs2
        • Apr 2009
        • 2455
        Doh! Sorry about that.
        Maybe this can help
        Eric
          Nice one thanks mate
          • Acidburn
            • 13459
            alex - i still hav that bracket for the fuel lines for you sitting here.
              cool, thanks mate
