First off, how I have not been on in a year I do not know, Hello again everyone!
Previously I have rebuilt the head as my gasket had blown along with sorting out numerous other issues. Today I tried to take it to MOT and it is still cutting at around 2.5k rpm occasionally under light load.
On the way to the MOT the engine coolant (about 7 miles driving) high / coolant level low light came on and I panicked, I stopped the car and the engine felt hot and the coolant was luke warm. Gauge wise the temperature was 2.5 marks above 90 and has never reached above 3 marks.
I thought initially the thermostat may be sticking and the coolant was not circulating as the hose at the bottom of the rad was cool and the top was very hot. I undid the coolant cap and it was not under a huge amount of pressure but when I did this I stated to get a bit of bubbling at the block.
I checked the thermostat, and it seemed to be ok, topped up coolant and bled through on the heater matrix screw with an elevated expansion tank.
When I shut off the engine without the cap on coolant overflowed with bubbles which must have been in the system and you could feel some bubbles in the top rad pipe. The Rad does seem pretty hot at the top but cool at the bottom and no hot water appears to be getting to the expansion tank until i shut the engine off.
Does this sound normal? possible thermo sticking? Possible air lock?
Am i just been paranoid because since changing the MFTS the coolant temperature is shown higher?
This damn car, I just want to drive it.
