Compression Test
  • s2tommy
    • Apr 2009
    • 169
    Compression Test
    Just carried out a compression test after damaging the hot wheel on my turbo!
    And would like some input from some people, as I am thinking the cylinder head is going to have to come off for a inspection!!
    I have je custom pistons 82mm c/r 8-5-1
    Stone cold engine, turbo is removed so can't start to warm up
    Wot
    1 - 10bar
    2 - 10bar
    3 - 8bar
    4 - 8 1/2bar
    5 - 9bar
    Cheers tom
  • Rusty
    • 18953
    Difficult to say cold but you'd expect about 10 Bar across the board. Best to be safe and take it to bits.
    • nip
      • Apr 2006
      • 1786
      • Home: United Kingdom Current: Abu Dhabi
      Wot
      1 - 10bar
      2 - 10bar
      3 - 8bar
      4 - 8 1/2bar
      5 - 9bar
      Cheers tom
      You should test the compression on a hot engine, also take put the fuel pump relay and hold open the throttle fully
      • s2tommy
        • Apr 2009
        • 169
        I can't do it with a warm engine as the turbo and exhaust manifold have been removed, but I did do it with the throttle wide open. I would expect maybe 1/2 bar differance between cylinders.
        • AndyP
          • 6049
          Factory spec is 9-13bar with a CR of around 9:1. They quote a maximum difference between cylinders of 3bar Personally I'd be happier with 0.5bar as you say. I'd pull the head off for a look if I were you.
          Or you could buy one of these and have a look
          http://www.ebay.co.uk/itm/USB-Endosc...item19d29fac38
          I've got one and they're really good
            AAN Compression Testing Procedures and Specs
            Just carried out a compression test after damaging the hot wheel on my turbo! And would like some input from some people, as I am thinking the cylinder head is going to have to come off for a inspection!!...Cheers tom
            Here is a link to AAN (or ABY and ADU) compression testing and specs
            • stocious
              • Jul 2012
              • 838
              Just bought one can't wait to try it out !!
              Always thought these were big money
              1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
