its
me mad, right here goes, the setup is 3076 turbo standard injectors, maf ,n75,ecu has a super chips chip in it.The set up also has bigger I/c, ported/polished head due to waiting to have it remaped im driving it around with no boost , problem is when the cars hot slowing down to a stop it cuts out or the revs drop to about 3-400rpm then when at standstill the idle starts to wonder, if I then rev it it puffs out a bit off black smoke.
things ive done
cleaned/changed isv
cleaned maf
changed vac pipes
vag commed with engine speed sensor fault
changed n-75
and coil packs
ive been told that due to bigger cooler/turbo its the map on the ecu hope someone can shed some light on it as its really driving me mad, have nearly come to to decision to break it
regards nip
