Forged pistons? rods? in stock...............
I need info about Audi APX egine
if you want more power,change pistons AND rod....www.stenparnermotor.se std bore are 81,00mm and the rod have 20mm xpin...the laterones are only 19mm 8-(( -
What is APX engine??? How many cylinders? How many valves?sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
APX is the Audi TT 225 engine, 1 oxygen sensor, Euro-2 emmissions specs, no EGT sensor.
They have forged pistons from the factory, rods are supposedly good, pretty good engine. I still prefer the AMK (210HP with 2 lambda sensors) and the BAM engines (225 with 2 lambda sensors) because of their extended diagnostics/EGT sensors/more advanced ECUs.
HTH,
Mihnea'98 Silver Grey 2.7T S4, dual 2.75" turbo back exhaust with no cats, FMIC, BIG injectors, 10 Bar motorsport fuel pump, modded RS4 turbos, tubular exhaust manifolds, custom intakes, RS4 MAF, Bilstein PSS9, H&R ARBs, 19" BBS CH, custom remap, 511 BHP/505ft-lbs
www.MRCTuning.com
info@MRCTuning.com
Workshop DirectionsComment
Hello Mihnea, can you give more info about AMK engine. Forged pistons? compresion ratio? How many hp you can make on stock engine?
Vytas
Originally posted by MihneaAPX is the Audi TT 225 engine, 1 oxygen sensor, Euro-2 emmissions specs, no EGT sensor.
HTH,
MihneaComment
