96 S6 auto, what is the standard boost set up?
    Originally posted by ChrisAudi80
    I was convinced there was a 01E 3.89
    Technically you are correct. However, I am not convinced that a 2004 A4Q 01E with 3.89 would be a plug and play in a 96 UrS6 autobox with 3.89 rear diff. It might be, I have just never heard of anyone using one in a C4.
    • ChrisAudi80
      • Oct 2011
      • 236
      • Home: Norway Current: Thailand
      #32
      Probably not PnP, but with this box no need to change the diff. The prop shaft, of course, and probably the front axles.
      However, the OP was asking about stock boost pressure on the auto.
      Way OT.
      FWIW, actually like driving the S6 auto now that it has the prj chip set.
      Now, if there was an affordable way to beef up the auto trans to handle say 500Nm, that would open up more possibilities.
      Right now it should be able to handle 410Nm according to Dmitri.
      '96 UrS6 auto PRJ chipped E85
      '95 80Q AEB VEMS E85
      • vag_nutter
        • Sep 2009
        • 164
        • Country: New Zealand
        #33
        It will bolt in exactly the same as any other 01e would.
        The only reason for going with the 3.89 tdi box is not having to change the rear diff as well.
        Also the long ratio 6th of the tdi box makes it a nice cruising gear
        • prj
          • Mar 2010
          • 6308
          2.5 seems too much for a MTM set, it should never hit that, unless the wastegate membrane has a hole in it or someone wound down the spring.
          • S8QUATTRO
            • Jun 2012
            • 101
            • Home: United Kingdom Current: United States
            #35
            how easy it is to upgrade to prj chips? is it a diy job at all?
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              #36
              From my experiences i have seen the ecu with socketed and non.both are stock never opened the ecu
              Before.if yours is socketed,it s easy to get it done.though if it was not socketed.if you have some
              Soldering skill.i believe you can get it done within 1-2hrs max.
              one of a few I5 from Asia.
