Vagcom in Bristol (or near)
  • gripper
    • Jun 2008
    • 1156
    Right, I think I would rather pay an enthusiast on here to plug Vagcom to my car than taking it to some backstreet garage who will probably tell me I need a new engine (or turbo)
    So if anyone has one and they are willing to (and have the correct lead) have a look at my A3 then please pm me to discuss prices.
    In addition if you come to mine I can supply tea, quality biscuits and even dinner in some cases
    Or I can come to you ?
    For what this cost me so far I could have bought an S2
  • Rusty
    • 18953
    I've got a basic lead to read codes but not much else...
    • Monkeymagic
      • Mar 2012
      • 3419
      Im in worcester and will happily help for free but its a bit of a distance.
      My advice buy a licensed programme it really is a great tool.
      • gripper
        • Jun 2008
        • 1156
        Ive got a purple plug under the ash tray at the front is this the diagnostic port ?
        • gripper
          • Jun 2008
          • 1156
          It cost more than the cars worth mate
          • Monkeymagic
            • Mar 2012
            • 3419
            Thats the one mate. I have a handheld fault scanner i bought years ago. Its basic but will pull codes easily
            Its another option for you. Defo check the pcv pipes and thin vac pipes under inlet manifold for splits they are common. Also bin the dv and put back to standard. VAG spent millions designing the engine and someone decided to change a vital part without any research
            • Ross
              • Aug 2005
              • 3399
              I'm in Swindon if your ever up this way, happy to plug it in and read codes.
              • 80Quattro
                • Sep 2006
                • 420
                • Home: United Kingdom Current: New Zealand
                Surely AllAudi would do it for minimal cost if there isn't someone local who can do it. They diagnosed a coil pack fault on my car for free last time I asked.
                92 Audi 80 Quattro => RS2 Saloon!
                98 TVR Cerbera 4.5
                63 Austin Mini Super Deluxe (turbocharged)
                69 Austin Mini Cooper
                71 MGB GT
                75 Daimler Vanden Plas 4.2L
                04 Kawasaki GPX250
                96 Subaru Legacy GT-B
                • gripper
                  • Jun 2008
                  • 1156
                  Big thanks to everyone who offered to help with this
                  Found someone now who is willing to do this and also has the parts to fix my coupe
                  Andy your a star
                  • gripper
                    • Jun 2008
                    • 1156
                    Thanks to Andy I now have a comprehensive (read large) printout of my vagcom error codes !
                    I can disregard the ones for interior lights and door contacts as these are the previous owners attempt at disco lighting
                    Central locking pump runs for a bit in the tailgate so I'm aware of that.
                    I have a air-bag light on dash so aware of that.
                    Found some ABS error codes but not sure why as its all working as it should ?
                    Then there are the engine codes
                    Saturday,31,August,2013,10:50:54:40053
                    VCDS Version: Release 11.11.6
                    Data version: 20121223
                    Chassis Type: 8L - Audi A3/S3
                    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
                    Mileage: 206150km/128095miles
                    Address 01: Engine Labels: 06A-906-018-AGU.lbl
                    Part No: 06A 906 018 AQ
                    Component: 1.8L R4/5VT MOTR HS D03
                    Coding: 04000
                    Shop #: WSC 06435
                    VCID: 71E3C1823B356F90DF5
                    4 Faults Found:
                    00544 - Maximum Boost Pressure Exceeded
                    35-00 - -
                    16500 - Engine Coolant Temp. Sensor (G62)
                    P0116 - 35-10 - Implausible Signal - Intermittent
                    00575 - Intake Manifold Pressure
                    08-10 - Control Limit Surpassed - Intermittent
                    01262 - Solenoid Valve for Boost Pressure Control (N75)
                    26-00 - Output Open
                    Readiness: N/A
                    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
                    Part No: 1J0 907 379 E
                    Component: ABS/EDS 20 IE CAN 0001
                    Coding: 13504
                    Shop #: WSC 06435
                    VCID: 336F0B8A01A91D80ED9
                    3 Faults Found:
                    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
                    35-00 - -
                    01276 - ABS Hydraulic Pump (V64)
                    16-10 - Signal Outside Specifications - Intermittent
                    01312 - Powertrain Data Bus
                    37-10 - Faulty - Intermittent
                    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
                    Part No: 8L0 820 043 D
                    Component: A3 KLIMAVOLLAUTOMAT_D75
                    Coding: 03141
                    Shop #: WSC 06435
                    VCID: 2953E9E2D3655750575
                    No fault code found.
                    Address 15: Airbags Labels: 8L0-959-655-AI7.lbl
                    Part No: 8L0 959 655 F
                    Component: Airbag 7 Audi 0505
                    Coding: 00104
                    Shop #: WSC 06435
                    VCID: 418351424B15BF106F5
                    1 Fault Found:
                    01218 - Side Airbag Igniter; Passenger Side (N200)
                    32-10 - Resistance too High - Intermittent
                    Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
                    Part No: 8L0 919 930 E
                    Component: AB-KOMBIINSTR. VDO D02
                    Coding: 04442
                    Shop #: WSC 00000
                    VCID: 38753CA618CFFED8D8B
                    Subsystem 1 - Part No: IMMO
                    Component: IDENTNR: AUZ7Z0V0237703
                    IMMO-IDENTNR: AUZ7Z0V0237703
                    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
                    Part No: 8LO 862 257
                    Component: ZV-Pumpe, DWA, Funk D03
                    Coding: 13130
                    Shop #: WSC 65535
                    VCID: 1123A1025BF50F90BF5
                    8 Faults Found:
                    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
                    35-00 - -
                    01371 - Alarm triggered by Door Contact Switch; Driver's Side
                    35-00 - -
                    01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
                    35-00 - -
                    01374 - Alarm triggered by Terminal 15
                    35-00 - -
                    01370 - Alarm triggered by Interior Monitoring
                    35-00 - -
                    01369 - Alarm triggered by Hood Switch
                    35-00 - -
                    01368 - Alarm triggered by Luggage Compartment Switch
                    35-00 - -
                    01373 - Alarm triggered by Radio Ground Contact
                    35-00 - -
                    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
                    Part No: 8L0 951 173
                    Component: Innenraumueberw. D03
                    Coding: 00001
                    Shop #: WSC 06435
                    VCID: EED95AFEAA0BF068427
                    End ----------------
