I've spent some time this week pulling my RS2 apart to get to the bottom of my overheating.
Tonight I confirmed the thermostat is not faulty and the water pump is not damaged, so that's all working as it should. I then plugged the radiator so i could pump water into the top and measure flow through the bottom. I don't expect it to flow i huge amount, but even with some pressure I couldn't get it higher than about 1l per minute. Letting water through from a pipie held about 18" above the rad it was about 0.5l per minute.
To me that sounds too slow, but then I have no idea what the flow rate of the water pump is or what it should be capable of.. it may be that is normal and adequate...
Any experience here? I'm tempted just to buy a new one as a spare (current is 5yrs old) and test that against it...
Hoping it's a problem as next it's head off
