Larger intercooler in a 20v urQuattro - is it worth it?
  • Ahonen
    • May 2006
    • 10
    • Home: Finland Current: Belgium
    Evening all,
    I've been a member here for ages and have read countless project threads but you've all covered everything so damn comprehensively I've never felt the need to ask anything - until now.
    My RR is having a bank-breaking restoration and I've been pondering fitting a different intercooler. I'm fitting an aluminium radiator and removing the auxiliary rad, so that leaves a neat area behind the grille for an intercooler in a nice high-pressure zone and unaffected by hot tarmac temperatures. From what I've seen this is a fairly common position for modified Type 85s, but I'm having doubts based on the following:
    1. I'm keeping the standard 'round the back of the engine' inlet manifold, so the extra piping up to the grille and back may adversely affect response times.
    2. I only have 250bhp or so (it's a very mild Nothelle 2.5 engine), so would I see much of a gain in anything but the hottest weather?
    So my question is: is it worth the trouble? Would I be better off making a thicker intercooler to fit in the standard position? Or should I just leave it as standard?
    Any thoughts or experiences greatly appreciated.
  • adam g
    • Feb 2007
    • 445
    Have you found a bigger intercooler that will fit in the gap, I found it was still too thin even with the aux rad removed. There was more room in the stock position when I looked at upsizing. This is why some people with a urq have gone twin intercooler set up when going for a front mount.
    Sent from my LT15i using Tapatalk 2
    • DJones
      • Jun 2005
      • 2020
      See if you can log your temperatures first, it will give you a guide as to if its worth touching for the 250bhp that you run.
      Welcome to the forum..
      Darren
      • Henkjan
        • 1705
        why nog break the bank a bit further and go for the reverse inlet (sq style of wagner)?
        • urq20v
          • Sep 2003
          • 218
          I have fitted both an alloy 4 row radiator and a larger intercooler to my RR urquattro.I removed the aux radiator and used that space to fit a 13 row Mocal oil cooler.The new intercooler is 80% larger by volume and fits in the standard position.Its hangs lower than the standard intercooler so it was not possible to refit the bottom cover,and it partially obscured the original oil cooler and caused higher than acceptable oil temps on the track.The original oil cooler was directed cold air through the vent in the bottom cover and without it,it did not get enough.The Mocal oil cooler cured the oil temp problem.
          • Ahonen
            • May 2006
            • 10
            Thanks chaps.
            I've half considered the reverse inlet manifold but, for the time being at least, I'll stay with the standard one.
            I had plans to relocate and upsize the oil cooler anyway, as I'm convinced the standard one is too small, so putting that behind the grille and making a larger intercooler may work well.
            • jsws3
              • Apr 2012
              • 1174
              I have a large intercooler for stock location for a ur that I bought for mine from a guy in Germany running rs2 spec and he said it worked well .
              I paid 260€ for it & delivery you are more them welcome to have it for what I paid as I'm going front mount on mine .
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                Does not fits in the front down like the S2 cars?
                • jsws3
                  • Apr 2012
                  • 1174
                  No mate it fits down the bottom left hand side of the car if you was looking into the engine bay .
                  • Ahonen
                    • May 2006
                    • 10
                    Jsws3, I'm certainly interested in that. If you could post a picture of it that would be very helpful.
                    • adam g
                      • Feb 2007
                      • 445
                      Do you have the core dimensions of the side mount, I may be interested.
                      How are you managing to squeeze a big front mount it, have you gone for the rally style extended grill mod?
                      • jsws3
                        • Apr 2012
                        • 1174
                        Ditching the spacer on the s2 box moving the engine back and fitting a made to order intercooler supplied buy vrs Northampton and running water meth to keep temps down .
                        • urq20v
                          • Sep 2003
                          • 218
                          I got my alloy radiator and intercooler from Dialynx in the UK,but I think they were both made by Pace Products.
                          • jsws3
                            • Apr 2012
                            • 1174
                            Pace did use to make them for Keith .
                            I contacted Ross at pace last year and they wanted £465 + vat for the intercooler.
                            • jsws3
                              • Apr 2012
                              • 1174
