turbo oil in oil out gaskets
  • stocious
    • Jul 2012
    • 838
    anybody got the part numbers for the oil in oil out gaskets ?
    1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
    Items 13, 14, 19 and 20?
    Turbo Coolant and Oil Feed and Return Lines: http://forums.quattroworld.com/s4s6/msgs/72682.phtml
    • stocious
      • Jul 2012
      • 838
      Good stuff Dave, Cheers
      • Christophski
        • 3632
        Guys, can I just ask a quick question... on the above diagram, is it the pipe that has the gaskets 19 & 20 on it that is the turbo oil feed pipe?
        • Ross
          • Aug 2005
          • 3399
          Yes, 19 is on the feed connection to the turbo and 20 is the feed connection from the oil filter housing. I thought they were slightly different but ETKA shows otherwise, perhaps I was thinking of the oil return line...
          • Christophski
            • 3632
            Cool thanks Ross
              Just to add what Ross said, Item 18 is the pressurized oil feed line (with the 19 and 20 gaskets) from the oil filter mounting housing and Item 12 is the oil return line (with the 13 and 14 gaskets) that drains back to the sump (by gravity I think).
              • Christophski
                • 3632
                Coolios Thats how I read Ross' reply thankfully lol. Its always nice having people back it up though.
