Hi guys,
I have a S6 2,2 T with RS2 7200 on RS2 EM. I recently converted it to LPG.
I have a bottle with 2 x probes, 2 x Magic 3 LPG evaporators, 2 x 8mm log hoses and a 2.4 mm nozzles on 1,5 OM. Management is done by AGIS.
Problem comes on full throttle between 3000 and 4500 rpm. The car stalls and when i release the pedal if accelerates again. After 4500 it is ok until 5300 when it switches to petrol.
Readings show that the pressure drops to 0.8 after 4000 rpm in these conditions.
Interestingly boost is around 0,7-0,8 between 3000 and 3500.
Do you have any idea how to solve this problem?
Thanks in advance
Sorry if i got the description wrong.
Please move my thread if posted in the wrong section.
Thanks in advance
