Power Loss ?
  • bilko0795
    • Feb 2011
    • 1883
    Power Loss ?
    Iv noticed that since I have changed the Maff the car will only boost to 0.8 and not 1 bar and when I fitted the homefry Ecu it only boosted to 1 bar and not 1.4. It doesn't feel aggressive it's more of a smooth acceleration. The Maff I have fitted is a brand new one from Audi, there are no boost leaks as they have all been sorted and all the coils are new. Just wondering if there any other reasons why it feels Dull.
    Check the female pins on the Mass Air Flow (MAF, not Maff) sensor harness connector. Sometimes they get pushed back in the harness and don't make full contact with the fixed MAF male pins.
    More MAF info: http://forums.quattroworld.com/s4s6/msgs/20442.phtml
    • bilko0795
      • Feb 2011
      • 1883
      Just a Address 01: Engine Labels: 895-907-551.lbl
      Control Module Part Number: 895 907 551 A
      Component and/or Version: 2.2l R5 MOTR.RHV HS D02
      Software Coding: PMC 1
      Work Shop Code:
      VCID: 224DA5E7AECD0D0EA27-4A58
      2 Faults Found:
      00516 - Closed Throttle (Idle) Position Switch (F60)
      29-10 - Short to Ground - Intermittent
      00513 - Engine Speed Sensor (G28)
      03-00 - No Signal
      Readiness: N/A
      just done a vcds check on the car and it threw up th codes above with the homfry ecu. I then changed back to the oem one and no codes were present. The homfry ecu is producing 0.9 boost and oem one 0.7 max don't quite understand whats going on here. Would a boost a small boost leak be the cause of the lack in boost.
