Just got my Mityvac from Premier tools. I have previously pressure tested TBV and wastegate actuator. Car ABY S2 Coupe. 4 questions:-
1) How much vacuum should be applied to the (lower) split tree at the rear of the IM to test ? 2) How long should it take for the vacuum to pump down ? 3) On this tree, one branch connects to a light pink hose that appears to go to the ECU/recirc valve - the other goes to a larger diameter hose that routes round the front n/s wing - where does it go ? 4) The upper rear hose connects to a valve (?) just in front/below the throttle body - is this the fuel vapour system or something else? Still learning! Thanks, James.
