Wastegate Actuator How many turns????
  • karlblues2
    • Jul 2004
    • 402
    • Home: England Current: Australia
    Hi guys
    Happy New Year
    Can someone tell me how many turns the top allen screw in the wastegate should be from fully tight? I know it has been messed about with previously and want to ensure it is correct now I am assuming that undoing screw lowers opening boost pressure and tightening screw increases the point at which boost opens the wastegate? Is this correct or am I full of poo this afternoon
    Ta in advance for your help
    Karl
    Oz
    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
    Audi 90 Quattro 20V 1989 7A
    Audi TTRS 2010 APR stage 2 +
    Triumph 675 Street Triple R
  • jameswkr
    • 538
    Karl, check the threads under "engine and turbo" - this has been (done to death) discussed in detail. Happy new year tinkering, James.
    • Dr H
      • 1175
      AFIAK the best way is to disconnect the WGFV and then adjust the spring until you get a max of 0.4 bar boost when driving. Then reconnect the WGFV.
      Although I am prepared to be corrected!
      • karlblues2
        • Jul 2004
        • 402
        Thanks Guys. Couldn't find it on search. Will try again.
        • karlblues2
          • Jul 2004
          • 402
          Mihnea help
          OK. Found the threads from 2003. However, given my impending upgrade parts, Mihnea, do I need to adjust the allen key to a different point
          PS And Mihnea, you scarlet pimpernel, its a long 2 hours :mischeif:
          • karlblues2
            • Jul 2004
            • 402
            Thanks Mihnea
            You have a PM
