Hi, I've got a strange running issue with a 3B engine. It will starts and run good, idles good, and drives good. The problem arises if it's left to idle for more than about 20 seconds.
The exhaust note changes, and if you touch the throttle very lightly the revs surge up and down, and engine note changes as if it's under load. Turn of and restart and it's back to normal again until it idles for more than about 20 seconds
Fault codes stored is 00533 idle speed adaption limit exceed.
So far I've pressure tested from the maf to just over 1 bar, and gone over everything with soapy water in a spray. Replaced the hose to the throttle body, injector seat and seals and reposition a few hose clips. Pressure tested again with soapy water. No more leaks.
TPS is adjusted correctly all the PCV system is new, hoses, valves etc. Idle valve seems to function correctly.
Any help would be appreciated, I know diagnosis is difficult over a form
Thanks
Martin
Thanks
Martin
